G-Code, CAD, and CAM => G-Code, CAD, and CAM discussions => Topic started by: octavioa on November 14, 2007, 07:32:44 AM
Am taking this opportunity to attach a file that I can't seem to get to align properly.
You will see that the bottom most rout is not aligned with the upper 12 routs. Or
vice-a-versa - the top 12 are not aligned with the bottom one. Whatever.
Would like help to get all aligned.
Thank you.
It is the way Mach draws the sub, the program will be ok.
Graham.
Hi Graham,
I appreciate the quick reply and understand what your saying -
however, running the program/cutting a part, I get the mis-
alignment. I'm sure it's in my code.
Thanks for your time and help,
Octavio
OK, I have had a 2nd look and the code needed a little adjustment at the start.
Graham.
(Rout Combs)
G20 G40
G0 G90 Y0 X0 Z.25
G52 X.35 Y.3
M98 P1234
G52 X.35 y1.1
M98 P1234
G52 X.35 Y1.9
M98 P1234
G52 X.35 Y2.7
M98 P1234
G52 X.35 Y3.5
M98 P1234
G52 X.35 Y4.3
M98 P1234
G52 X.35 Y5.1
M98 P1234
G52 X.35 Y5.9
M98 P1234
G52 X.35 Y6.7
M98 P1234
G52 X.35 Y7.5
M98 P1234
G52 X.35 Y8.3
M98 P1234
G52 X.35 Y9.1
M98 P1234
G52 X.35 Y9.9
M98 P1234
M30
O1234 (Sub routine for routing combs)
G00 X.352 Y.500 Z.25
G01 Z0 F20
X1.102
X1.132 Y.900
X1.252
X1.282 Y.500
X1.402
X1.432 Y.900
X1.552
X1.582 Y.500
X1.702
X1.732 Y.900
X1.852
X1.882 Y.500
X2.002
X2.032 Y.900
X2.152
X2.182 Y.500
X2.302
X2.332 Y.900
X2.452
X2.482 Y.500
X3.482
Z0.25
G52 X0 Y0
M99
Hello Graham,
Yep, that did it. Thank you.
One last question on this part program -
From the display you see that the .062" router bit
cuts interlocking (?) combs. The problem is when
you actually rout the part the tip dimension of the
teeth are not the same. They differ by approximately
.020".
Can cutter compensation be used to correct this?
And if so - how?
Octavio
If some are correct and some are wrong then it is a program fault or cutter push, this can not be compensated for using cutter comp as the comp is applied all over the part(s)
Try changing the feed rates and/or the order in which the cuts are done. You may need to leave tabs at the end of the combs and take them out last.
Graham.
Thank you Graham for your help.
Changed the part program - was easier than I had anticipated.
Octavio
