Mach Discussion => Mach4 General Discussion => Topic started by: chainds on March 03, 2024, 01:03:10 PM
I am befuddled with a simple problem using Mach4. I am unable to change the values of any of the DROs in the Probing Tab. For instance, I cannot modify any of the values in the Probing Settings tab. Offset Number, G code: G, Slow measure feedrate,... Am I missing something operationally and I am not supposed to be able to change them?
Which build number of Mach4 are you using? Could you upload a copy of your screenset file?
