Mach Discussion => General Mach Discussion => Topic started by: 80gus on February 03, 2024, 02:26:10 PM
Hi all, recently acquired a CNC Clotting machine. and stated retrofit, it has a y Axis and a A xais and the head is in of off with inputs to show bottom of stroke and top.
what im trying to work out is how to make some basic code that when input is activated move y axis negative, wen input is activated move y azis positive (same as negative vale and extra)
This will happen to create a single tooth and then rotate a axis and go again.
ive searched and not found anything just yet. can anyone point me in the correct direction?
Is this using the digital dream control?
If so we can not help.
