Third party software and hardware support forums. => Sieg Machines => Topic started by: ART on November 11, 2007, 11:32:11 AM
Hi All:
Sieg machines are starting to use Mach3 more and more, so this board is started as a place to get specific
information on Mach3's interface to those machines. Hopefully, we'll have a Sieg owner moderate this forum.
ArtSoft has been in close contact with the Seig factory, and we will use this board for any pertinant information
for Seig owners as we recieve it. Please feel free to post any questions, or setup files for the Seig series of machines.
Art
The Sieg CNC mills should hit the market early next year or spring. The KX3-Mach and KX1-Mach are cnc mills running under Mach3 controller. The KC6 cnc lathe will be next in line to run under Mach3 controller. I am presently testing one of the KC6.
Weedy
The speed of both KX1 and KX3 will be more faster.
Im having trouble configuring the machine to mach3 someone please help
That is a rather vague question... Would be glad to help but you must first tell us what problem you are having (what is or isn't working/moving) which machine you have and such. Give us some information to work with and you have a better chance of getting some help.
it has to do with configuration....what is everything suppse to be? Its a KX1 and when i calibrate the axis so that when i move the axis 1 inch the DRO will read one inch. But when i turn mach3 down for the day and start it up next it sounds like the gears are grinding. Im new to this type of operating system and im not really sure what the settings are suppose to be with anything.
Are you selecting save settings at the bottom of the "config" box?
I turned my Sieg machine on today and needed to use it to square a piece up before running a program and i cant get the jog feed to adjust. I'll push tab and turn it up to 100% and its still the same speed. Then I'll turn it down to 5% and its still moving the same speed. I've tried restarting the Mach 3 and i get nothing. Anyone have any solutions?
:-[Hi I have just bought a Sieg kx1. If i go into ports and pins and disable the xy&z limits activate x y &z home switches but when I try to home the machine the mill drives the z axis to the home switch the mill stops movement but the Z axis keeps increasing. The first thought was that the z axis was hitting a hard stop so I lowered the Z axis activating arm the mill stops when it hits the home switch and I have 1 inch of travel left before it hits the hard stop
Help
Malcinc
What is sounds like is this - the limit also cionnects to the Axis Drive. The axis Drive is stopping because you hit the limit, but Mach is no longer seeing this as a limit so Mach keeps putting out pulses because it thinks things are still moving.
Here's a Manual Homing sequence that works and is repeatable.
First - Jog all axis near (less than 1 ") the "Home" position. Tap the <TAB> key to bring up the Jog Pendant, change Jog Mode to Step and distance to 1".
Select an unused offset, On the offset screen type in 239 for the offset and make sure all values are 0 (zero)
I start with the Z axis - I now hit the Jog Z Up key and wait for the Z axis to hit the limit switch and stop moving and the E-Stop is flashing. Reset teh E-Stop. on the MDI Screen type G92 Z0 and the DRO for Z will read 0.0000. Now zog the Z axis away from the limit and wait for it to finish moving 1".
Now repeat for each of the other axis.
I do this on a KX3 and have very repeatable results.
I hope that not too many people think that this is an embarassingly simple question, but can someone please tell me how to set the soft limits on a Seig X3 mill in Mach 3?
I am new to CNC but I am an ex (very) press toolmaker.
Thanks in anticipation
Eugene
