Mach Discussion => Mach4 General Discussion => Topic started by: bycole on January 10, 2024, 01:41:30 PM
Hello,
I started on Mach 3 and now I'm on Mach 4. Is there a way on 4 to highlight the toolpaths as you are scrolling through the G code? I can't figure out how to turn that on in 4.
thanks
It is there you just can't see it. You will have to go to 'operator->edit screen' then click on the 'Toolpath' component that you want to change and then in the tree to the left change line width of the path to a larger number. get out of edit screen and regen toolpath.
HTH
RT
