Mach Discussion => Mach4 General Discussion => Topic started by: pjcevallos@gmail.com on November 12, 2023, 05:03:38 AM
Title: Homing for Absolute Encoders
Post by: pjcevallos@gmail.com on November 12, 2023, 05:03:38 AM
Hi
Following this thread, https://www.machsupport.com/forum/index.php?topic=47822.0
I wonder what is the procedure when you have absolute encoders for homing operation.
At the moment we do not home the machine as the absolute encoders remove the need for a physical limit switch.
In fact, the Origin is set as an offset. Whenever we need to go to "home", we put G53 x0 y0 z0, and it goes to place.
We have tried to "home in place" when the machine is in its origin, but it tries to move and makes a bad noise.
Just wondering if our approach is wrong. Maybe I am overthinking it.
kind regards
Pablo
Title: Re: Homing for Absolute Encoders
Post by: KatzYaakov on November 17, 2023, 02:37:49 AM
hi
we use on our machins mach + absolut encoder
yes the only way its home in place ehile homing procedure read the encoder value update registry
the the registry called as ofseet
i use my applicateion rs485  to read the value ,the application exe from comand line from mach so actualy for user its same one click
its wasnt so wasy to make all that procedure but finaly its work good
