Mach Discussion => Mach Screens => Machscreen Screen Designer => Topic started by: JSAUNIER@YAHOO.COM on October 31, 2023, 01:37:38 PM
HELP! I can not get the Properties Dialog to appear on the screen. Is there a key sequence that will force it to the top or center of the screen. Full disclosure; I have designed a vertical(Portrait) screen; on a horizontal(landscape) PC' had no issues with the screen showing. I need to do some fine tuning on the actual machine(portrait); but the properties Dialog can not be found anywhere. Alt-Tab does not show the window, it is not outside the active screen window...
use menu Options -> move property dlg into view.
Klaus
As my wife would say, "If it was a snake it would have bit you!" Thanks.
