Mach Discussion => Mach4 General Discussion => Topic started by: Fermate on October 26, 2023, 07:04:24 AM
Title: ESS Software Velocity FIFO ran out of data
Post by: Fermate on October 26, 2023, 07:04:24 AM
Hi
I am running a Mach4 (4.2.0.5036 B 5036) with a ESS (v275) on a i7 (3.6Ghz) PC  with 16GB ram.
The Mill is an old Multicam where I have replaced the controlsystem on by adding a EES/MB3 and some MA860H drivers.
The PC is configured with the Smoothstepper Configuration Utility (v.2.0.5.2) that turns off Windows processes etc.
Now and then a am experiencing lost steps on different axes that ruins my work.
I have tried to reduce the Motor Speeds and Acceleration, adding a condensator on the powersupply and lastly I turned on the "Show Software Velocity FIFO Ran Dry Msgs" checkbox in the ESS Configuration.
When I start up Mach4 now I get the "ESS Software Velocity FIFO ran out of data" error as soon as I make some Axis move and it keeps coming.
I have tried to replace the Network cable between the PC and the ESS and are out of ideas.
Before I start up the work of replacing the PC and reconfiguring a fresh version of Mach4/ESS, I want to check with you guys if the thing I experience are a known problem and maybe not related to my missing steps problem at all.
Any tips or help would be appreciated.
Gaute Espeland
Norway
Title: Re: ESS Software Velocity FIFO ran out of data
Post by: Tweakie.CNC on October 26, 2023, 09:16:55 AM
Have you tried increasing the ESS buffer size ?
Have you tried reducing the ESS plugin frequency ?
Both of these suggestions are made by Warp9 to eliminate the FIFO out of data issue.
Post by: Fermate on October 26, 2023, 10:15:03 AM
Yes I have tried increasing the ESS buffer size, with no change in result.
BUT I have not tried reducing the ESS plugin frequency, thanks for reminding me.
Do you have any information on the range of change and the possible consequences of getting it too low?
Post by: Steve Stallings on October 26, 2023, 11:06:00 AM
There was some trouble with motherboards using the Intel Gigibit Ethernet chips. Drivers were updated by Intel. Any chance that yours could be one of them?
Post by: Fermate on December 05, 2024, 04:06:47 AM
For other people reading this.
I updated my ESS to V285 and the error message disappeared, but not the problem
To me its looks like the skipping steps problem are related to big G-Code files (more than 1 000 000 lines)
I have posted a new thread for this
