Mach Discussion => General Mach Discussion => Topic started by: iw2nzm on November 09, 2007, 01:24:24 PM
Title: How to invert axis coordinate
Post by: iw2nzm on November 09, 2007, 01:24:24 PM
Hello,
I'm puzzling over an easy task. My X and Y axis are inverted respect default setting. Well, changing either the dir active low flag (in output signal window) or the reversed flag (in homing/limits) actually inverts the rotation of that axis. But after homing the positive side is towards the home switches and moving the motors to correct side leads to negative coordinates values.
I followed the procedure described in the video tutorial but without success. Maybe I misunderstood some settings.
So I ask you: what should I check to fix the issue?
Marco / iw2nzm
Title: Re: How to invert axis coordinate
Post by: iw2nzm on November 10, 2007, 05:47:08 AM
Solved. It was too simple. Sorry for waste bandwidth.
Marco / iw2nzm
Post by: vmax549 on November 13, 2007, 07:14:36 AM
SOmetimes you have to SEE the question in PRINT for it to JOG your brain into action. I do it all the time. (;-) TP
