Mach Discussion => Mach4 General Discussion => Topic started by: jjneeb on October 07, 2023, 06:21:35 PM
I feel like this is staring me in the face, but I can't find it.
If you double click in the Mach4 Gcode window, it will add the line number to the display which will stick for the Mach4 session. Is there any way to make that the default mode?
thanks,
Jim
first I'd ask why you want to see the line numbers? I don't believe you can use those in any function calls. Its only for the editor itself. Bob :-\
Sometimes things go south, then its nice to know where in the file the problem was so when I go back to debug it, or start it again the next day I know a little more accurately than "in the south side of a 500k line Gcode file".
why not simply place line numbers in your generated GCode? If you are doing by hand I'd guess the files aren't that large. If your generating thru a CAD system most should be able to add line numbers. Bob :o
There are a half dozen reasons why one of my files may not have line numbers. Generally, I prefer the app to display the numbers if possible, putting numbers in the file makes the Gcode 10-20% larger, and really messes up hand editing (cut and paste especially).
My offline editor displays line numbers, and so does Mach4's built in editor. The display window can as well - I just want to know if there is a way to make that window default to displaying the line numbers please.
I don't see any method as it seems part of the display function. Maybe one of the adminstrators can be of assistance and point you in the correct direction. Sorry. Bob :-[
Did you try double clicking inside the GCode tab window? If I do that then I see line numbers.
