Mach Discussion => Mach4 General Discussion => Topic started by: adiniz on September 04, 2023, 08:31:23 AM
Hi all that uses Tangential mode in Mach4!!
My machine running Mach4 Hobby in Win10 with a CSMIO/IP-A controller is losing tangential settings in the Tangential tab! >:(
If I put the adjustments manually, they don't have any effect when restarting Mach4!
My output is being to replace the entire C:\Mach4Hobby folder with an old one!
Has anyone had this problem?!
Thank's in advance!
I checked this and all of the tangential settings save correctly. Are you running a recent build?
Steve
Hi Steve!
We are using Buil 4300
Version 4.2.0
Thank you!
Yeah, I can't even test that one. We are on build 5199 at the moment. You may need to upgrade. :(
https://www.machsupport.com/ftp/Mach4/DevlopmentVersions/Mach4Hobby_Installer-4.2.0.5199.exe (https://www.machsupport.com/ftp/Mach4/DevlopmentVersions/Mach4Hobby_Installer-4.2.0.5199.exe)
Install it in a different directory and test it out first. Then make sure you save you modifications (if you have any) to your screens and profiles before you upgrade completely. There are some posts here on this forum somewhere that describe what you need to do when upgrading.
Steve
Ok Steve!
I will install, test and send you a feedback.
Thank you very much!
