Mach Discussion => Mach4 General Discussion => Topic started by: mediumSasuage on August 23, 2023, 09:04:47 AM
Hi All,
I am trying to use a macro to move to a specific line within the GCODE. To do so I am trying to use the command
mc.mcCntlSetGcodeLineNbr(inst, GcodeLineNew)
However, this does not seem to run and I can't figure out why. My wonder is whether it is actually supported in LUA because in the API it has a C/C++ example only whereas most other commands have an example for C/C++ and LUA.
Does anyone know anything about this or even know of a better way to skip through GCODE to a specific line.
Many thanks
I have found a couple of things that are not quite correct in the docs.
Sometimes with variables you need "" or ''
Try both of these.
mc.mcCntlSetGcodeLineNbr(inst, 'GcodeLineNew')
mc.mcCntlSetGcodeLineNbr(inst, "GcodeLineNew")
Hi Bill_O
Thanks for the tip but that did not work. Now it just breaks out of the macro rather than running past the line.
Beyond my knowledge if that did not work.
I would like to know how to do this if you get an answer.
The way to do this is using MACRO B. This means you'd have to have industrial.
https://www.amazon.com/Fanuc-Custom-Macros-Peter-Smid/dp/0831131578
Above I've linked you to the reference material MACH's MACROB adheres to.
I'm relatively sure the API call not working as you'd expect is due to the trajectory planner. (Note: The API does state this call cannot be used during GCODE execution.)
For instance, when the planner gets to the point where it's lookahead sees the macro it cannot look into the macro and predict the line you're attempting to go to.
Whereas using the MACRO B function GOTO the planner can see that and interpret it, then plan accordingly.
Perhaps you can use a #VAR if you need to change the line it's going to. I'm not going to pretend to be an authority on this matter though and smurf would likely give a much better explination :) Hope this helps!
Yes, the GOOMBA is correct. MACRO B is the way this is done in the main stream and mc.mcCntlSetGcodeLineNbr() will not work when the machine is running (as stated in the API manual). This API is used by external scripts or GUIs to set the line number. As in where you click on a G code line in the G code list when the machine is IDLE. The IDLE state is important, otherwise, the user could click lines in the G code list while the machine is running and cause all sorts of mayhem and chaos.
And here is when I also get on my soap box about checking the API return codes. Because if the API was implemented in C/C++ but not implemented in LUA, it would simply be an unknow function to LUA (macro would produce a runtime error) OR the function call would return mc.MERROR_NOT_IMPLEMENTED. Either way, there would be no mystery why the API call didn't work.
All that being said, you could possibly use the mc.mcCntlSetGcodeLineNbr() when the machine is IDLE by first calling mc.mcCntlCycleStop(), then waiting on the state to become IDLE and then calling mc.mcCntlSetGcodeLineNbr() followed by mc.mcCntlCycleStart(). It was never meant to function like this, so your mileage may vary. You cannot jump to a N label in the G code with this. Only the physical line number. Obviously, this would NEVER work in MDI mode as there isn't a real notion of line numbers in MDI and the function would try and set the G code file line number instead. And you may have to wait a bit after the call to mc.mcCntlSetGcodeLineNbr() to allow the GUI to update its notion of the line number. I can't remember if the function is synchronous where the line is set by the time the function call completes or asynchronous where the line number is set lazily. Again, caveat emptor!
local inst = mc.mcGetInstance(inst, 'Trying to do the impossible script')
local lineNumber = 12 -- the G code line you want to jump to. It is base one, so 12 is line 12 and not line 13.
local rc = mc.MERROR_NOERROR
local state = 0
rc = mc.mcCntlCycleStop(inst)
-- Wait until the machine state is idle.
state, rc = mc.mcCntlGetState(inst)
while (rc == mc.MERROR_NOERROR) and (state ~= mc.MC_STATE_IDLE) do
wx.wxMilliSleep(10) -- Sleep for 10 milliseconds
end
rc = mc.mcCntlSetGcodeLineNumber(inst, lineNumber)
if (rc == mc.MERROR_NOERROR) then
-- We got the proper return code from the API
-- telling us that there are no errors.
rc =mc.mcCntlCycleStart(inst)
if (rc ~= mc.MERROR_NOERROR) then
-- Some error happened.
end
-- if the code path gets here, the machine SHOULD be in File Running mode.
-- However, it is a good idea to check for the idle state at the end of any M code macro.
-- This lets you catch any action a user may have taken to stop the machine while the M code was running. E-Stop or Cycle Stop, etc...
if rc == mc.MERROR_NOERROR) and (state == mc.MC_STATE_IDLE) then
-- The user must have aborted the G code!!!!! You can handle this gracefully if you needed to here.
end
end
Obviously, if you are trying to make API calls like this work, this means you are trying to make Mach do something that is doesn't do out of the box. Luckily we provide the API to make this possible but understand you are now programming. And you have to get your mindset right to program any device. It isn't a human. It isn't going infer anything. And it may make assumptions that you are not. So treat is like it is a 3 year old kid. You have to tell it to do everything step by step. I mean EVERYTHING. Including error checking.
Anyway, I hope this helps,
Steve
