Mach Discussion => Mach4 General Discussion => Topic started by: daseitz on August 19, 2023, 03:07:17 PM
Title: Mach4 xbox configure questions
Post by: daseitz on August 19, 2023, 03:07:17 PM
I've searched and can't find anything on the xbox button configuration.
The dropdown has selections that I don't know what they do. Like the "xbox cont/inc toggle" or how to use the "user gcode1" selection.  may be missing something but is there any descriptions or documentation for this?
The one thing I wanted to do was to increment move an axis like pressing the arrow keys or the screen buttons in incremental mode. Is it possible to do this?
I thought of writting gcode and using the "user gcode1" but so far can not figure out how to use those selections.
Still trying though.
Thank you for any help.
Title: Re: Mach4 xbox configure questions
Post by: daseitz on August 19, 2023, 05:36:23 PM
Upon further trying I found Gcode1 in the registers under XBox.   I put in G0X1 and the xbox button does execute the code.
The problem I have now is I need to put in G91 then G0X.001 then G90. How can I put this in a register?
Post by: daseitz on August 19, 2023, 06:50:37 PM
After working on it all day I finally found out putting G91\nG0x.001\nG90 will work.
As far as knowing what the button commands in the xbox plugin are I still don't know.
Isn't there some documentation on the xbox plugin available somewhere?
I can't believe it was written and not explained at all.
Post by: massynrt on December 11, 2024, 11:08:55 AM
I was searching for a way to use the user Gcode on the xbox - At leat now I have an idea as I could not find any documentation.
  Maybe, a better way would be to add gcode to Mcode macros in the registers.
User Gcode 1 -  Only add M770 or something - The go write the macro in Lue to execute the code.  I will test this tomorrow.
