Mach Discussion => Mach4 General Discussion => Topic started by: chaney on July 26, 2023, 05:21:45 AM
So I updated Mach4 setting up a new machine, and now all of the sudden my current machine won't run properly.
The motors will not respond/move.
If I restart Mach4 a hand full of times, they will finally respond.
As soon as I try homing, they move to the first or second switch.
At this point the machine stops and I get multiple pop-ups saying "HOMING_PREP failed waiting for FIFO to drain”.
Now nothing works again.
I have no idea what FIFO is.
Can anyone provide any ideas how to correct this issue?
Thanks in advance for any advice.
I have the same problem but some days it does it ...then some days it works good.
I get this error when trying to home.
I had done mutiple reinstalls(Windows and Mach4)...in the end replaced the computer that solved machine crashes, not doing tools changes and spindle not shutting down.
As I was explained to me this is a communication error.
so I have a new ESS board on its way that should take care of this problem...will update as the board is installed.(Next week)
Board replaced same problem ::)
You may need to decrease the plugin frequency and increase the buffer size. Take a look at this link https://www.warp9td.com/index.php/gettingstarted/setting-up-the-smoothstepper-and-mach4#SetupESSCommunications:~:text=ESS%20Step%202%20%2D%20General%20Tab%3A (https://www.warp9td.com/index.php/gettingstarted/setting-up-the-smoothstepper-and-mach4#SetupESSCommunications:~:text=ESS%20Step%202%20%2D%20General%20Tab%3A)
You may need to decrease the plugin frequency and increase the buffer size. Take a look at this link https://www.warp9td.com/index.php/gettingstarted/setting-up-the-smoothstepper-and-mach4#SetupESSCommunications:~:text=ESS%20Step%202%20%2D%20General%20Tab%3A (https://www.warp9td.com/index.php/gettingstarted/setting-up-the-smoothstepper-and-mach4#SetupESSCommunications:~:text=ESS%20Step%202%20%2D%20General%20Tab%3A) pizza tower (https://pizzatower.online)
This solution works for me. Thank you
The answer to all my problems was the version of Mach4 and the Warp9 plugin.
I uninstalled the latest versions and went through a list of older releases until I got the combination of build and version.
Everrything now works as it should.
I hope this helps out someone else as I was really fustrated with this.
Thanks everyone. :)
