Mach Discussion => General Mach Discussion => Topic started by: Jivac on July 07, 2023, 07:12:45 AM
Can I control the axle movement directly with the pen on the graphics display? Where and what settings should I ask? Thank you for your attention
Assuming you require accurate X and Y axis machine movement replicating the pen movement from a tablet…
There is no current facility for it to be done within Mach but it could be possible if the output from a graphics tablet was compatible with, just for example, the output from a CNC Pendant and suitable drivers were present.
Certainly an interesting possibility for anyone adept at writing the driver software plugin.
Thanks for the reply. I realized that the task was quite difficult.
