Mach Discussion => Mach4 General Discussion => Topic started by: FiveO on July 01, 2023, 09:48:23 AM
Title: Build 4809 to 5153 Hobby, now with industrial look?
Post by: FiveO on July 01, 2023, 09:48:23 AM
Hi
upgraded from 4809 to 5153, and now I have industrial/darker gray look? How to switch to that original light gray screen look?
Title: Re: Build 4809 to 5153 Hobby, now with industrial look?
Post by: thosj on July 02, 2023, 08:52:06 AM
Reinstall 4809, go copy the screenset out to somewhere, install 5153 and add the old screenset to it.
You COULD do this with directory renaming, too. Rename Mach4Hobby to Mach4Hobby_5153, install 4809 which will create a new Mach4Hobby directory. Copy the screenset you're interested in from 4809 install. Name folders back, Mach4Hobby to Mach4Hobby_4809, Mach4Hobby_5153 to Mach4Hobby. If you have other customizations, you will need to take those into account, too.
Post by: FiveO on July 08, 2023, 11:55:30 AM
Thank You!
Post by: thosj on July 08, 2023, 01:02:23 PM
NOW you may find your old screen isn't compatible with the 5000+ versions of Mach4. That's what I learned:)
Post by: tantan on July 08, 2023, 01:45:39 PM
version 5133????? i cannot find any version higher then 5036???
Post by: Steve Stallings on July 08, 2023, 02:00:21 PM
Version 5133 is a beta release. You can download it from here:
https://www.machsupport.com/ftp/Mach4/DevlopmentVersions/
Yes, development is actually mis-spelled, but the link is correct.  8-)
Post by: tantan on July 08, 2023, 02:04:02 PM
aah, great thank you!
