Mach Discussion => Mach3 under Vista => Topic started by: Vido on February 28, 2023, 10:46:36 AM
Title: OEM Code for referencing wrong?
Post by: Vido on February 28, 2023, 10:46:36 AM
Hello, I have a list of oem codes that says the oem code for referencing the x-axis is 1022. If i click the referencing button under "edit button script" in Mach3, the code behind this button is displayed. However, this code says "DoButton(22)" and not "DoButton(1022)". The same applies to the other two axes. Is my list of OEM codes wrong?
Title: Re: OEM Code for referencing wrong?
Post by: Vido on March 01, 2023, 01:49:27 AM
Referencing is independent of the machine type. The OEM code list I have is from Mach3 and this applies to milling, turning and plasma cutting.
