Mach Discussion => General Mach Discussion => Topic started by: Horacio100 on February 14, 2023, 11:23:07 AM
A few days ago I bought a parallel port BOB, I was doing the tests to use it with mach3 first putting the configuration that the manual said (https://robu.in/wp-content/uploads/2016/07/5axis_breakout_board-EN.pdf ) and when I have everything ready and it is time to connect everything mach3 does not want to feed the pins that I ordered, I ask that pins 2 to 5 will be the ones that I will use for the Y and X axes, instead it energizes other pins as it is In the case of 4 to 7, assuming that the card was defective, I did a parallel port test for it and a multimeter to see if it energized and turned off the pins as ordered in the software and there it did, which gave me to understand that the card was working fine but when using mach3 it doesn't (again) i already tried to just keep using mach3 with that problem but now it comes when i want to use other pins and it doesn't even use them
I checked the diver test that comes inside mach3 to see if it was under control and yep, I don't understand why this happens and how I can solve it
(sorry if my english is bad)
Are you sure you are using a 1 to 1 parallel cable and not a modem type.
nope i am using a parallel cable 25 pins
i use two cable, paralell and usb
I just confirmed and yes, the cable is 1 to 1
