Mach Discussion => General Mach Discussion => Topic started by: DanieGouws on December 29, 2022, 03:12:16 AM
Title: Mach3 Not saving the current tool number at shut-down
Post by: DanieGouws on December 29, 2022, 03:12:16 AM
Hi Everybody,
I run Mach3 on an OMNI router with a ATC spindle. All works fine except the system function, current tool number, is not stored during shut-down. I assume all system functions would be saved in the XML configuration file? What am I doing wrong?
Kind regards and thank you
Danie
Title: Re: Mach3 Not saving the current tool number at shut-down
Post by: TPS on December 29, 2022, 05:17:22 AM
try:
Config -> General Config -> Axis DRO properties -> Tool Selection persistent
Post by: DanieGouws on December 29, 2022, 05:56:20 AM
Thank you very much!
Regards Danie
