Mach Discussion => Mach4 General Discussion => Topic started by: mwc273 on December 25, 2022, 02:24:02 PM
Title: Control PoKeys57cnc built-in relays from Mach 4
Post by: mwc273 on December 25, 2022, 02:24:02 PM
Finally getting around to trying to switch a router on and off from Mach 4.
The PoKeys57cnc has 2 built-in relays.
I cannot seem to find a way to enable/disable these relays from Mach4.
I want to use the built-in relay to switch power to a larger relay to switch power to a router.
I have an external 18vdc power supply to run the PoKeys57cnc board (better than USB alone)
Passing that 18vdc through the relay 1 terminals to the large external relay to handle the 120vac.
Have been all through Control Configuration and PoKeys plugin configuration with no success.
Found a YouTube video showing how to do this in Mach 3 that made it look easy.
Can someone please point me in the right direction?
Oh. And Merry Christmas everyone!
Title: Re: Control PoKeys57cnc built-in relays from Mach 4
Post by: mwc273 on December 25, 2022, 09:18:52 PM
OK. Made a little progress!
Configure > Control > Output Signals (tab)
Enabled #10 & 11, Device PoKeys_42701 PE, Output Names Relay 1 & 2.
Now need to figure out how to trigger #10...
Would be nice to map it to the Spindle CW / Stop (M03 - M05) button functionality, then I could add M3 and M5 commands in my G Code.
Post by: mwc273 on December 25, 2022, 09:29:35 PM
Unrelated question...
I attached a screenshot to the previous reply, but I don't see it, nor do I see a way to view it.
How do look at attached files on this forum?
Cheers!
Matt
Post by: Tweakie.CNC on December 25, 2022, 11:27:17 PM
Hi Matt,
This thread details making attachments to a posting;   https://www.machsupport.com/forum/index.php?topic=24585.msg173822#msg173822
Post by: mwc273 on December 26, 2022, 08:09:40 AM
Update:
Scrolling down the Output Signals list in the previously mentioned Mach 4 Control Configuration, I saw "Spindle On" as a choice. So I moved the output mapping from "Output #10" to "Spindle On". Still need help getting this mapped to the "Spindle CW / Stop" button on the "Program Run" screen.
And thanks for the link to info about adding files @Tweakie.CNC.
Post by: mwc273 on December 26, 2022, 08:48:10 AM
More info:
The Mach 4 Output Wizard shows me I'm on the right track.
I can successfully trigger Relay 1 from the Output Test.
Post by: mwc273 on December 26, 2022, 09:47:49 AM
Got it working as desired.
In the words of Chief Dan George in The Outlaw Josey Wales; "Endeavor to persevere."
Post by: Tweakie.CNC on December 26, 2022, 11:04:15 PM
