Mach Discussion => General Mach Discussion => Topic started by: boydage on December 16, 2022, 03:20:56 PM
Title: Do I upgrade or not bother?
Post by: boydage on December 16, 2022, 03:20:56 PM
Ive been using Mach 3 for years. Always cautious I just need a push in the right direction please.
I still dont know how to build a wizard or macro. Thats me. In the constant desire to upgrade, my next mission is to install an ATC, the mechanics will be a piece of cake, the programming, well, I found the perfect person to help with Mach 3. I do need to upgrade my old BOB - the same BOB I have used for years. Its so full of inputs that I had to build a relay bank to accept both NO and NC inputs to put out one NC onto one pin ha
Anyways. My upgrade to an Ethernet Controller. If I remain with Mach 3 I have someone who can build the macros for the ATC, for a cost of course. If I upgrade to Mach 4 I have no idea what do do. Im not a novice installer but I would be reluctant if there is a whole heap of work to get my machine up and running with the upgrade. How hard will it be to get help to complete this mission should I upgrade to Mach 4 is my question. And then install a ATC. All the online recommendations point to Mach 4. My gut points to Mach 3 just because it would be easy with the help I have found.
The machine is being used for personal and commercial.
Title: Re: Do I upgrade or not bother?
Post by: Monty12345 on December 17, 2022, 08:13:46 AM
programming for a ATC in mach3 is not a problem. I've even used it to control a Dorian 8 position turret. It has a bunch of interlocks and event driven commands to make it work. That machine uses an old Bob Campbell break out board and a second serial port for all the IO. You should be able to do what you want in Mach3, unless you just want to change over.
Post by: joeaverage on December 18, 2022, 01:12:14 PM
Mach4 is a learning curve, and you'd hate it to start with but once you got up to speed you'd see that its light years ahead.
https://www.machsupport.com/forum/index.php?topic=42891.msg278176#msg278176 (https://www.machsupport.com/forum/index.php?topic=42891.msg278176#msg278176)
