Mach Discussion => General Mach Discussion => Topic started by: Fredrik on December 11, 2022, 10:09:25 AM
Title: Mach3 Homeswitches, ARF 6040 cnc
Post by: Fredrik on December 11, 2022, 10:09:25 AM
Hi
When i do Ref all home my machine dont back of my homeswitches, Yellow lights turns on in diagnostiks, M1,M2,M3.?
When i jogg machine of home the switches lights go of,
Howe do i fixt so the machin back off the switch When its triggerd ?
Fredrik
Title: Re: Mach3 Homeswitches, ARF 6040 cnc
Post by: reuelt on December 11, 2022, 11:07:35 AM
Your machine is travelling too fast when you "ref all home".
I think the softlimits are set incorrectly. Softlimit settings must be set to slow down the speed to 40% when spindle approaches the home switches or soft limits.
Check with your user manual.
Post by: Fredrik on December 11, 2022, 11:42:25 AM
All my Numbers are typed in  from the manual,softlimits, speed in manual are set at 40%, i tryed at 20% but it doesent helpt.
Post by: reuelt on December 11, 2022, 11:52:19 AM
Are you using metric units?
The slow zone of 1  is correct if you are using inches but should be 25 if using mm
(Remember: pirated copies of Mach3 from China will not work correctly)
Post by: Fredrik on December 11, 2022, 12:09:40 PM
Yes in in metric, and in my manual the slowzone number is 1, i Will change to 25 and test.
