Mach Discussion => General Mach Discussion => Topic started by: Sambonnie on October 23, 2022, 05:03:50 AM
Morning all finaly got a work around to get my machine up and running,
On doing so i need to alter some code in one of the files.
Symtoms
When i start a Gcode of to machine the Z axis comes down to +60mm above the work plane. then the spindle fires up and work commences.
my issue is I have a job thats 100mm thick and i only have 22mm above the material and cutter.
any easy way to change that 60mm to 20mm??
regards Tom
Managed to find the issue and resolve,
On my M6 Start macro the Z was set to Z60. so changed to Z20 can cut 100mm again,
I'd suggest you delete that line of the macro, it will o ly cause trouble later.
