Mach Discussion => Brains Development => Topic started by: Bodini on October 29, 2007, 02:33:51 PM
I want a brain to:
if gcode is running then -> output5
I tried:
LED804->greater than 0-> output5
but that doesnt work.
Is that how you get the signal from an led, like in VB? (0 for off, 1 for on?)
Basically, the condition I'm looking for is: if gcode is running, then do it... if you're jogging by hand, dont do it.... which is why i didnt just link it to blended velocity, which did work as a test.
thanks,
Nick
Dont need the greater than zero part... set it to 'no operation'.
All you do is choose to do nothing, ie pass through the signal and it should work.
yup, bout 20 seconds ahead of ya. ha! :P thanks hood.
