Mach Discussion => Mach4 General Discussion => Topic started by: Stuart on September 20, 2022, 04:32:18 AM
I have just had a look at your vidieo for the above , looks very nice indeed , I have used it in the dev releases
but ( there always is ) its very good to check a running machine , say to test out one or two inputs/outputs/registers etc but when you need to redo a profile the old GUI drop down is better to give a overhaul picture of the machine state when testing .
my very crude solution to this was to to deconstruct a older screen set to just have only the diagnostic panel and load this as required as in your new probe screen set .
as a compleatly different question what is the recommended monitor size/aspect ratio for mach4
keep up the good work
Stuart
