Mach Discussion => General Mach Discussion => Topic started by: kolias on September 03, 2022, 09:20:08 AM
My C11G BOB has four 5V terminals on the Inputs side and the schematic provided for connecting the Limits indicates all 5V for the Limit to go to one pin. I decided to spread the 5V to other 5V pins to make a better looking job but then the problem started (thought all 5V terminals are the same).
All limits alone work properly and when I’m in the diagnostic screen I click the Ref X, Ref Y it works properly, but when I click the Ref Z then I get the message “Requested Home Axis is Used, Fix the Wiring and try Again”.
A+/Home is on Pin 12, Y+/Home on Pin 11, Estop on Pin 10, Probe on Pin 15 and all the rest on Pin 13.
I wonder if the problem is on Mach3 configuration or my wiring.
