Mach Discussion => General Mach Discussion => Topic started by: Carsen on July 31, 2022, 08:27:51 AM
Hi all,
A while ago I converted Mach3 to run from metric to SAE. Everything works ok, I re-calibrated the motors, no problems running programs or jogging from the keyboard but I can only get the xbox controller to jog at 5% full speed. I tried so many things before asking for help that I,m at a loss right now. Tried removing and reactivate the xbox controller in the plugins, tried disabling and re-enabling the xbox controller in the peripherals of windows etc. Before , when I was in metrics, it would jog at the same speed as if you use the arrows on the keyboard but not anymore. Has anyone run in that situation before? If so what was your solution? Thanks for taking the time.
