Mach Discussion => General Mach Discussion => Topic started by: garyn on June 02, 2022, 09:57:03 AM
Title: multiple depth cuts
Post by: garyn on June 02, 2022, 09:57:03 AM
what do I need to do to make the Shapeoko cut multiple depths?  I want to cut 3/4" plywood with 1/4" bit in 2 passes.  I have tried saying the bit will only cut 3/8" at a  time, but the tool path shows cutting the plywood in one pass.  What do I need to change?
Title: Re: multiple depth cuts
Post by: JohnHaine on June 02, 2022, 10:27:24 AM
What CAM package are you using?
Post by: garyn on June 02, 2022, 10:33:27 AM
I am using Carbide Create and Carbide Motion.
Post by: JohnHaine on June 02, 2022, 10:38:00 AM
So this is a Mach3 support forum so I doubt people will be familiar with those.  Mach3 is more or less the same as Carbide Motion I think.  Do they not have a similar support forum?
Post by: garyn on June 02, 2022, 10:40:20 AM
Sorry about that
Post by: JohnHaine on June 02, 2022, 12:24:24 PM
Not a problem, just that the expertise probably isn't here.
