Mach Discussion => Mach4 General Discussion => Topic started by: edcross on March 28, 2022, 01:33:46 PM
Have a 4x screen set in my profile now , i want to replace it with a laser screen set i have . When i go to view and hit load screen ,it goes to the screen set folder , click on the set i want and it shuts mach down ????
thanks
eD
It's not a Mach3 set is it? Won't work if it is. Otherwise, don't know other than the set file is corrupt somehow. Did you create it yourself or download it somewhere? Mach4 screens aren't as prevalent in the wild as Mach3 screens were:)
If i create a new profile , it does work , but if i try to load into a existing profile , it closes Mach 4.
Ed
If i try to load any other mach screen set from Mach , it does the same thing !
Ed
Could you provide me with some more details so that I can duplicate it? I will see what we can do to help you?
Mach 4 v 4612 , what ever screen set i try to load , Mach4 closes . I have a profile that works and has w4. screen set , if i try to change it to a different screen set , Mach 4 closes , at times i get a debug report screen but it does not send the report . I go to view - load screen set - pick a set from the screens folder in Mach - hit ok and mach 4 closes.
I got the answer on the Warp 9 forum , thanks for your help .
Ed
For future seekers.....
The answer is here:
https://warp9td.com/index.php/kunena/7-general-discussion/9176-mach-4-laser-screen
What surprises me most is no one here knew this work around or apparently had even heard of it!!
Amen !
Ed
