Mach Discussion => VB and the development of wizards => Topic started by: Philipp Kleinheider on February 06, 2022, 12:57:50 PM
Title: Toolchange command and Mach3 being strage
Post by: Philipp Kleinheider on February 06, 2022, 12:57:50 PM
Hi all!
For the last moths I've been trying to program a semi automated toolchange command. But it just won't work.
I have a small Router for which I bought a laser light barrier to act as a height sensor.
I want the cnc to move to the toolchanger location and if it is the first tool in the program
rapidly move down to a safe height (that is calculated using the last tool length in the tool table) and measure the old tool and store its length. Then it should move to a position where I can easily change the new tool and measure the new tool (while using the stored length of the old tool) like before and then apply the tool length compensation.
All I have managed until now is a function to probe the tool. But it is acting very irregularly. When I freshly open Mach3 it works as expected and starts from the correct position, but when I repeat the Machto the Probing position is shifted down.
Here is my M998 Macro to test the function:
Sub main()
    Dim a
    zerotoolL = 27.7
    a = gettoollength(1, -83.456,false,100,10,zerotoolL)
    ' if a = 9999 then
    '     MsgBox "Error"
    ' End if
End Sub
Function gettoollength(tool, ZProbe,isreftool,SearchSpeed,SlowSpeed,zerotoolL)
    Dim zmachine
    Dim ZDRO
    Dim startzheight
    Dim distZmachineProbe
    Dim ProbeinDRO
    XProbe = 10.34
    YProbe = 42.25
    Code "G00 G53 Z0"
    Code "G00 G53 X" & XProbe & "Y" & YProbe
    Sleep (100)
    While IsMoving()
    Sleep(100)
   Wend
    'MsgBox "got to probe location"
    zmachine = getParam("ZMachine")
    ZDRO = getParam("ZDRO")
    distZmachineProbe = ZProbe + zmachine
    ProbeinDRO = ZDRO + distZmachineProbe
    'coordinateoffset = zmachine - ZDRO
    'Code "S1000 M3" 'Annoying (tool would have to spin for better accuracy with the laser)
    if isreftool = true then
        zheight = 0
    Else
        'MsgBox "Not ref tool"
        toollength = GetToolParam(tool,2)
        knownlength = toollength - zerotoolL
        'MsgBox "toollength from" & toollength
        'MsgBox "toollength compared to old tool" & knownlength
        startzheight = ProbeinDRO + knownlength + zerotoolL + 10
        MsgBox "startzheight =" & startzheight
        zheight = ProbeinDRO + knownlength + zerotoolL -10
        MsgBox "End height =" & zheight
    End if
    'MsgBox "Hi 1"
    While IsMoving()
    Sleep(100)
   Wend
    Code "G00 Z" & startzheight
    'MsgBox "vor messen"
    Code "G31 Z" & zheight & "F" & SearchSpeed
    Call WaitProbeReady()
    'error = WaitProbeReady(1)
    ' if error = 9999 then
    '     Exit Function
    '     gettoollength = 9999
    ' End if
'I tried to use the Waitprobeready as a function, so it would spit out an Errorcode if the probe didnt trip but then the whole Macro didnt work
    measuredZ = getParam("ZDRO")
    Code "G00 Z" & measuredZ + 1
    Code "G31 Z" & zheight & "F" & SlowSpeed
    '     Exit Function
    ' End if
    gettoollength = getParam("ZDRO")
    MsgBox gettoollength
End Function
Sub WaitProbeReady()
    Message "Waiting for Probe to trip"
    Sleep(1000)
    n = 0
    While IsMoving()
        Sleep(100)
   Wend
    While not GetOemLED(825) and n < 50
       Sleep(100)
        n = n + 1
        Message n
    Wend
    if n > 49 then
        MsgBox "Error Probe did not trip!"
        'WaitProbeReady = 9999
    End if
End Sub
It would be extremely kind if anyone could help me or at least explain what is going on, or even show me a new macro that simply works, because I don't wnow what to do anymore.
Thanks Philipp
[Im sorry for any grammar/spelling errors and my really bad code]
Title: Re: Toolchange command and Mach3 being strage
Post by: Graham Waterworth on February 08, 2022, 07:07:06 PM
Are we talking about changing cutters or fixed tools in a repeatable chuck e.g. BT30 holder?
