Mach Discussion => General Mach Discussion => Topic started by: hitchhiker on February 03, 2022, 05:18:21 PM
Title: mach3 turn postprocessor for fusion360? (turning,threading g76)
Post by: hitchhiker on February 03, 2022, 05:18:21 PM
hi! i look arround cad cam and want to know if there a postprocessor is avaible to use it dith fusion360 and mach3.
i think biggest problem is threading with g76.
has someone a working pp?
thanks!
Title: Re: mach3 turn postprocessor for fusion360? (turning,threading g76)
Post by: RICH on February 03, 2022, 05:55:52 PM
It's been a few years since I used Fusion 360 lathe. It does provide good code for use by Mach3.
If my memory is correct,  from one of the pull downs you can access /  download load different post processors.
Just for reference  you may find the CPS in the following directory of your PC:
C:\Users\user\AppData\Local\Autodesk\webdeploy\production\890691bd91ea0296c1b94572fdc7dda4ba2e48f0\Applications\CAM360\Data\Posts
You can edit them to customise, BUT, you better know what your doing. There was a video on how to edit them, about 1 hour long, that I watched and educated me on how to make changes.
Have Fun,
Post by: hitchhiker on February 04, 2022, 12:13:04 AM
good morning, i thank you.
another question.
if there a programm available which works direct with mach3?
I think the biggest problem is g2 g3 and css and threading or?
thanks
Post by: RICH on February 04, 2022, 05:24:02 PM
Use the Wizards, Lazycam, Lazyturn, Meshcam, Wrapper, Fusion 360, Dolphin / Partmaster  .....whatever gets the job done the easiest for what
for what I want to do. Last would be hand writing the code.
Try Free Cad and other programs .........................
Post by: hitchhiker on February 05, 2022, 06:09:05 AM
https://forums.autodesk.com/t5/fusion-360-manufacture/mach3-turn-postprocessor-for-g76-threading/m-p/10929292
mach3 turn pp fully working wizh fusion
