Third party software and hardware support forums. => Newfangled Solutions Mach3 Wizards => Topic started by: Ron Ginger on October 21, 2007, 07:33:02 PM
Title: V2.75 ready for test
Post by: Ron Ginger on October 21, 2007, 07:33:02 PM
I have a new version of the wizards ready. This has several changes and some bug fixes.
A major change has been made to the Tool Selection screen. I hope it makes it more clear, and insures all parameters are updated. I believe in the old screen many guys were not getting the Feeds and Speeds updated. I also added a button to read the tool table if you want to instead of entering the number and diameter. Thanks to Pat Lorenz for help on this one.
I also made major changes to the Surface wizard. It now makes even width cuts based on 75% of the tool diameter. Before it made The first cuts even, then did a narrow cut for whatever was left. In some cases it made an extra unnecessary move. Fans of Rudy Kouhoupt will like the look.
I also added a G code window to the Preview screen, and fixed the initial conditions to make the previews work correctly.
The zip file is attached to this post. Please check it out and let me know of any bugs. In a week or so I will ask Art to include this version in the Mach release.
Now that I know there is a manual I will be updating it for this version in the next few days.
thanks,
10/25, edited to update zip with tool table fixes
10/26, tool table now handles all 255 entries and can skip over blanks. Still no description, but Art has promised a function so I can fix that
10/31 Fixed top of material in Surface wizard
I have removed this version, see the new topic for V2.76
Title: Re: V2.75 ready for test
Post by: vmax549 on October 21, 2007, 10:01:57 PM
Hi ROn it looks really good, But I did find some bugs and offer some suggestions
1.  TOOL properties page it will not let you make a manual entry for the tool selection, it accepts the number but does not update the info.
2.  The tool selection table needs to include the tool description. I have 6  different .500" tools but can't select one without knowing what it is.
3. the tool selection table will not select tool#1  it  just lets you know you must select a tool.
4. The tool table selection does not have a scroll bar to allow you to see all the tools it just display 1-6 that all.
5. some of the  wizards allow you to set TOM (top of material) other assume the TOM =zero. To be usefull as a program code assembler you need to be able to assign what the TOM is. ( really important)
6. On some wizards such as the rectangular pocket there needs to be a reference as to what the width and length refer to is the width Y or X axis, is the length Y or X axis.
7. On the drill wizards there need to be a reference as to what the starting angle is referenced to y or x axis and where is zero.
8. On some wizards the term pitch is used on others it is plunge/ramp on others it is ramp angle. These terms need to be the same for consistancy .
9. On wizards that have a drill or hole function the terms step depth, depth,peck depth should just show a value based on TOM  and not allow the +/- sign this can be confusing to newbies. or does the +/- apply to this function??
10. on the code preview you need to add a rewind button so you can preview the code and tool path easier the second time( GOOD idea the gcode window) Good for proofing the code.
All in ALL a very good step forward. I look forward to using them. (;-) TP
Post by: vmax549 on October 21, 2007, 10:06:02 PM
MT??
Post by: mayhugh1 on October 22, 2007, 01:57:11 PM
When trying to run any of the electrical shapes operations, I get an "Error on line 53 - Path not found" . It seems the wizard is looking for a Shape TAP file in the G-code directory that doesn't exist.
Post by: Ron Ginger on October 22, 2007, 06:50:35 PM
Yes, there should be a Shapes.tap file in the Mach\gcode folder. It should have been installed by the mach install. I will attach a copy here.
Post by: Ron Ginger on October 22, 2007, 07:58:10 PM
Works for me- are you sure you are pressing enter?
Sorry, Art does not make the description available, just the tool params- numbers, not strings. I see the need, but cant be done.
Found that and fixed it, it will be in the release version
I added 8 tools and a scroll bar pops up just as expected. It works for me.
Yes, this has been raised before. Its a big change, I will try to get to it.
Yep, and on the old surface wizards it was confused inside the code- I dont know how that one ever worked. I will try to clean this up.
It assumes the CAD convention, 0 degrees is 3:00 O'clock
Yep, Ive fixed a couple places, Ill get the others.
On most of them I think the code handles the + or - OK. You can enter either, it takes the ABS() of the number and uses it correctly.
Yeah, I thiught the Gcode window was usefull- it helped me debug the code, so I thoughtit would be good. I just use the scroll bar to move around, Ill see if I can add a rewind button.
Thanks for all the review.
Post by: vmax549 on October 23, 2007, 07:27:19 AM
Blog entries (0)
« Reply #5 on: October 22, 2007, 06:58:10 PM »
*****I am assuming that if I enter a tool# that the diam info will update to reflect the change If so then it does not work. If that is NOT how it works then it should(;-) IF you are goint to use the tool table info. If that is NOT how it works you need to explain the process
*****You could add a label along with the TOOLDESC function to display the description of the selected tool,, also did not ART add a new command to retreive the string for use in VB???
****I have 52 tools and the display only shows 6, and there is NO scroll bar and the up/down buttons scroll but only through 1-6. THat is ALL that displays
*** YOU might consider adding a reference to the picture on the screen so everyone will know that(;-)
Post by: Ron Ginger on October 23, 2007, 07:46:52 AM
No, that should not work. The idea is if you want to get the data from the table you press the button and select it. If you do NOT use the tool table then you can enter the number and diameter directly into the DRO. Some will likely leave the tool number as 0, just enter the diameter.
The note I saw only lists the numeric tool table values. I will look a bit deeper. The TOOLDESC would allow me to display the description AFTER it was selected, but not in a way I can pick it up for the list box.
Do you have a gap in your list- an unused tool at #7 maybe. The code reads the tool table params unti it gets a null. There is no way to tell how many tools there are.
I was warned the tool table would be a can of worms !
Post by: vmax549 on October 23, 2007, 09:02:40 AM
Blog entries (0)
« Reply #7 on: October 23, 2007, 06:46:52 AM »
#### BUt what if you left say too# 6 in the input box then used diam of say .250. The wizard is assuming a diam of .250 but Mach will call the tool #6 which could be .500????
Catch22(;-)
#### AT least when the tool WAS selected the description would show up and you could verify it was the one you really wanted.(;-)
##### I have always wondered why the tool tables were setup and used(description) the way they are. To know a tool diam is useless without the description. It could be one of 10 types of tool bit configurations(;-) As it is I have to keep an updated CATALOG of the tool table to know what is what. SEEMS conterproductive to me(;-)
###### AH I see that you are using the diam field as the identifier. NOT good, My problem was the tool# 7 is a drill. we do not assign a diameter to a drill to prevent it from having comp applied accidentally in a program, we do however use the height to comp(;-). If you are going to use the tool table you have to show ALLl the table as SOME people have some tools that are set in certain ranges for a reason. Using your method there will be gaps and will not display the entire tool table
#####NOT really a can of Worms just can be complex. If you treat the tool table as a whole and don't take any shortcuts it is easy to deal with. THat way no matter how someone can invent a new way to use it, it can be used.(;-)
Post by: vmax549 on October 23, 2007, 10:49:14 AM
HEY RON I just noticed that the NFW will now assemble a group of programs together as a single Gcode file.
EXCELLANT JOB. You now have the makings of a WORLD CLASS converstional interface to MACH3. Just clean up a few little things to make it consistant and you will sell a million copies of this one once everyone finds out about it.. A GOOD manual will be neccasary as well. (;-) BUt once you get to understand the principle it is VERY easy to understand.
I just assembled a very complex duplexed part that normally requires several hours to create. USING NFW It took about 15minutes(;-) and NO CAM NEEDED
We were also able to create both halves of the assembly. These parts even had drill patterns and tapping( slight of hand trick here, used a drill pattern and edited in the G84 tapping cycle instead of the drill cycle(;-) ) IT had a spot cycle , drill cycle, and a tapping cycle at each hole location.
Just a couple of notes::
The TOM (Top of material) setting is absolutley a must for this to work correctly. Each component of the program may require a different setting.
At the end of each segment Mach needs to return to a safe Z  that will be consitant with all segments to prevent crashes due to different material heights and clamps, etc.
Could you add in the line numbers??? It would make it so easy to redit if needed. Sometimes tough to find the line to edit if there are hundreds of lines of code.
In the drill pattern wizards could you allow the G84 tapping cycle along with the drill cycles. It works SO NICE. We use the G95 feed per rev and set the thread pitch as the feed ( 1/TPI=F rate) and the G84 cycle to tap with. Does an awsome job. Just have to remember to cancel out the G95 and the tapping cycle when done.
NOW I am going to have to create a NEW training project. The old one just became obsolete as it is now TOO easy to do with the NFW.
ONCE again GREAT JOB
Post by: Ron Ginger on October 26, 2007, 10:19:04 AM
I just modified the first topic to replace the Newfangled.zip. This new version now handles the full 255 entries in the tool table, skipping over those that have a zero dia tool. Still no description, but Art has promised a function for the next Mach version.
Post by: vmax549 on October 26, 2007, 02:23:36 PM
Ron would it be possible to list ALL tool table entries?? Normally we do not enter in the tool diam for Drills,taps,boring heads,etc but we still need to see them for possible use in the wizards.
Thanks (;-) TP
Post by: vmax549 on October 26, 2007, 07:37:03 PM
Ron the update works well . With the tool desc applied at least you can see what you have loaded. I still worry about inputting a tool number then changing the dia separately. I see a disasster coming up with the wizard thinking one thing and Mach another. I have seen this happen when somone changed out the tool but did not update the tool table(ME)
Post by: vmax549 on October 26, 2007, 07:39:03 PM
Ron, would it be possible to print out a project summary that listed all the important info including the tool#/size  required for the total project?? THat way you would have a list of all the things needed to start the project including a tool# list so you can update the tool table if needed.
The old way was to start with an empty tool table and update it before running the file. Then when done empty the table back out. Pretty much fail safe that way was.
Just a thought, (;-)TP
Post by: Ron Ginger on October 26, 2007, 08:11:23 PM
Art has promised a new VB function that can read the description from the tool table, so when that happens I should be able to make this look much better.
I could list the entire 255 entries of the tool table in the list box, but that might  make things very slow, and much harder to read. This whole tool table thing was supposed to make entry SIMPLE not more difficult.
Obviously a wizard cannot know that the operator has screwed up the tool table. If you use tool tables I suggest you do it VERY carefully.
I suspect most use of the wizards is for simple, one-off jobs by guys that dont even use the tool table. I have never used it on my mill, I had to fill one in so I could test this code.
I have been adding more comments to the Gcode as I work on the wizards. I intend to make each one write all its major parameters at tehtop of each operation. Its good documentation and it helps me debug.
I am not about to try to make this poor VB script system try to print sumary data. It is an interesting thought to create a separate file with just the wizard input data.
Post by: vmax549 on October 27, 2007, 06:52:59 AM
Hi Ron , conversational programming it not just for a few simple projects. It is a modern programming interface that is used widely in the machine tool world. Pretty much the wave of the present and future. Best to get on board the train NOW. You have to think beyond a few newbies trying to figure Gcode programming out(;-)
To make it a best seller you will have to cater to both the beginner as well as the seasoned pro.
If you want tool tables to be SIMPLE you have to treat them that way. Just display the entire tool table and leave it up to the programmer on how best to implement them. I just loaded up the entire 255 entries as a test, looks fine from here.
I don't have problems using the tools tables they can be a handy tool. BUT just like using an ATC you just have to make sure they are loaded correctly(;-)
The empty dia trick is used a lot by people that use the tables as a programming TOOL.
So if you can write the summary to the Gcode, why not give the option to send it to a printer?????
""It is an interesting thought to create a separate file with just the wizard input data. """ NOW YOU ARE THINKING, that is the summary data you need to be able to print(;-). Tool data, feeds,speeds,ETC,anything that can be a reference to someone that has NEVER seen the project before having to run it.(;-)  We used to get handed jobs all the time that we personally had never run before. THe summary allowed us to verify the setup BEFORE running the code.
 Each project we do that is not CAM generated we have to hand write all the important data that will stay with the project file for life. THat simple idea will save tons of work over the years.
The trick here is to give access to ALL the handy tools of conversational programming for the pro yet keep it simple in context so it does not LOOK overwhelming to the beginner.
The new interface DOES look and work WELL, Good Job.  Please remember I am not picking on you, just trying to help you along and help test things when I can.
Post by: Ron Ginger on October 28, 2007, 11:08:14 AM
Funny to be on the other side of this conversational debate. My first experience with real CNC was when a good friend bought an AcuRite MillPower system. That does ONLY conversational, it didn't allow Gcode at all. I got so excited about it I wrote a similar program that ran under Win 3.1 See http://plsntcov.8m.com/CNH.htm for some info on it. That system worked really well, and I actually made parts with it- the screen shots show a part for a traction engine model I built that actually was made with the software.
That software used a dll driver that could not be ported after Win95. I came to Mach because it promised an interface that could be called from VB. I was going to  port my code to use Mach as a 'back end' I re-wrote it all into very good quality object oriented VB, but I was never able to get the Mach.ocx to work. I don't think anyone else ever did either and Art eventually quit talking about it. I met Brian Barker when I took my code up to U Maine to show him
So, I really like conversational approach. Actually, I am more into what I call 'Interactive Milling' I like an interface that lets me define parts and simply run them without ever having gcode involved. Thats the MillPower model.
MY problem with the wizard set as it exists is the poor VB script environment. I could do lots of neat things to the wizards, but since every button is its own environment and cannot see or use subroutines form any other button or source it becomes very difficult- maybe tedious is a better word. For example if I wanted to add a 'process sheet' to each wizard the code to do it would have to be included into every screen. Ok, so cut and paste would make that possible, but if i ever needed to make a change Id have 20+ places with the same code to change. I consider that un-supportable.
I don't mean to knock the wizard set- for what they do they work very well and a lot of guys have done a lot of work with them. I will support them, fix bugs, and make minor improvements, but I'm not going to try to make a whole new environment out of them.
What I am doing now is learning Flash and Action Script 3.0 That will be a VERY powerful capability and one could build a nice, interactive, conversational package on it. I'm a long way from being able to do that, but I am working on it.
Post by: vmax549 on October 28, 2007, 07:46:08 PM
RON don't give up yet. I am not a programmer but maybe it can be made to work. if it was  done back then, then it should be able to be done now(;-) Never say never just get clever.
What was it that would not interface, I do know that mach is very cranky with VB at times(;-)
You are correct in that the future of machine tools is interactive programming. My oldest son has two Masters in machine tool related technology and they have created some very interesting gizmos dealing with CNC machines and extreme high speed machining.
Lets lay it out to ART once again, it is starting to get cold up there he may need an interesting project to work on.
Post by: Ron Ginger on October 29, 2007, 03:20:13 PM
I have edited the manual to reflect the changes in V 2.75.  Art has placed a copy on the FTP site, and I have sent it to Scott to include on the Newfangled site. Its to big to attach to this forum.
Let me know if you find any errors.
Post by: vmax549 on October 30, 2007, 07:34:58 AM
Ron I do not see it on any of the sites. Let us know when it gets posted and I will look it over.(;-) TP
Post by: Ron Ginger on October 30, 2007, 10:28:46 AM
Its on Newfangled, but the link is still broken. Here is a direct URL that will work.
http://www.newfangledsolutions.com/downloads/Manual-V2-75.pdf
Post by: vmax549 on October 30, 2007, 09:07:43 PM
Hi ROn good job. Just a couple of highlites to consider.
Page 14  Start Position Button  should read as "XY reference position" same with screenpage.
Page16/17  Start angle decription should read the same as page 11 start angle description
Operational:
Cut circle grooving does not appear to cut correctly it appears to be using a lead in arc instead of inline feed. Only simulated did not actually cut it but both the circle and groove produce identical code in simulation???
Thread milling an inside thread SHOULD cut from bottom to top not top to bottom. If you cut from top to bottom you are driving the mill INTO the chip load not away from it. Good way to break small expensive thread mills.
Would be nice to include the G84 threading function in wizards that have drill patterns. Half of the holes we drill are threaded. Contrary to popular belief Mach does an excellant job with SR tapping using the G95/Gg84 tapping cycle.
Wizards do a good job if you are just one offing programs but without being able to SET top of material height it is pretty much handicapped from producing usefull full program code.
Just some thoughts, (;-) TP
Post by: vmax549 on October 30, 2007, 09:55:09 PM
Ron you might want to check the thread milling wizard it looks like the inside and outside processes are swapped.
Also there appears to be a lead in problem with what should be the inside process. It gouges down thru the thread then moves in and starts the helix upward.
Post by: vmax549 on October 31, 2007, 01:38:41 PM
Ron if you need any help just holler. I can build screens and modify JPGs if needed. I could also update the MACH help file system so when you right click on the item it brings up the help wizard. I have mine set to speak the file also. I notice most of the NFW functions are empty in the help file.
Post by: Ron Ginger on October 31, 2007, 04:38:22 PM
I just updated the wizard in reply 1 of this topic. I found a bug in the surface wizard that was not handling the top of material correctly- it actually dives into the work and tries to cut the last pass first. Not good !
Post by: Cruiser on November 04, 2007, 06:21:49 PM
Mach is real good at telling us a problem is in line number such & such, so then i count 1 2 3 4 .  . . .. ..347 348 ! can we get a button for number / renumber ?
Post by: vmax549 on November 05, 2007, 01:21:02 PM
Hi RON, did you get a chance to check out the thread milling wizard yet?
Post by: scottdunbar on January 13, 2008, 06:05:43 PM
Hi Ron,
Will you be fixing the circular groove problem soon?
Scott
Post by: Ron Ginger on January 13, 2008, 08:47:25 PM
I just today did a major re-write of the thread milling wizard, and I think its now correct. Ive sent it off to Brian to put in the Mach kit.
I also corrected the tool table screen, it now includes the description field, and correctly handles metric tool parameters.
I have not worked on the circular groove yet. I will try to get to it tomorrow.
