Mach Discussion => Mach4 General Discussion => Topic started by: TTalma on December 24, 2021, 11:03:36 AM
Title: how do I pulse a relay for my blast gates to turn on/off?
Post by: TTalma on December 24, 2021, 11:03:36 AM
My blast gates on my system are controled with a pneumatic cylinder. I would like to automate opening and closing the blast gate with the system.
I need to send a short pulse to open the blast gate and a short pulse to close it. If I control these with M7 or M8 for on, and M9 for off. A continuous pulse is sent to the relays opening/closing the cylinder.
How do I set the system so that a short pulse is sent with M8 or M9?
Or can I do something different and some how send a command when the spindle is turned on?
I'm just not sure what the correct way to do this is.
Title: Re: how do I pulse a relay for my blast gates to turn on/off?
Post by: rhtuttle on December 25, 2021, 01:34:16 PM
Winging it here.  Just an approach.
Create a register: GateState, set it to 0
Add to your M3 macro
local mInst = 0;
if (mcRegGetHandle(mInst, "core/global/GateState", &hReg) == MERROR_NOERROR) {
   rc = mcRegSetValue(hReg, 1);
Add to your M5 macro
local mInst = 0;
   rc = mcRegSetValue(hReg, 0);
in the start script declare a variable LastGateState and set it to 0
In the signal library Check to see if the state has changed
mInst = 0;
   local gatestate = mcRegGetValue(hReg, 0);
if LastGateState~=gatestate then{
  send your pulse
  lastGateState=gatestate
Syntax is probable wrong but you get the idea.  Someone else may have a better method.
HTH
RT
Post by: TTalma on December 28, 2021, 10:23:58 AM
This is great thanks. I get the idea.
After thinking about for awhile I decided I am going to use a couple of unused M commands. I mill aluminum semi regulary, and don't want the DC on then. If I create custom M codes that would be better for my situation, although I will have to manually insert them in the output that fusion creates for me, But no big deal.
Post by: DazTheGas on December 30, 2021, 01:47:40 PM
Just create your m7 or m8 macro and within this just turn your signal on then back off, if its too quick then just add a wxSleep after the signal on.
DazTheGas
