Mach Discussion => Mach4 General Discussion => Topic started by: GeorgS on December 09, 2021, 05:20:51 AM
Hi together,
I am wondering about this behavior. CV dist. settings seem to work fine up to a feedrate of 3000 ( mm/min). at higher feedrates, here 6000 the toolpath overshoots up to 3mm. ( cv tolerance 0.1mm for this application ( milling foam). It is not just a display error, I can see this error on my parts.
Look ahead lines also increased from 20 to 200, does not help.
( green lines: Gcode tool path )
white lines: real movement of machine
any ideas?
Georg
