Mach Discussion => Mach4 General Discussion => Topic started by: Toshio.K on December 04, 2021, 06:46:09 AM
Hello everyone.
I am migrating from Mach3 to Mach4.
I don't know about the following points, so please tell me.
In Mach3, the rotation speed of the spindle is confirmed by the Hall IC (DN6851).
In that case, the [Ratio] of Mach3 is set to 2.
In the case of Mach4, should I set "FeedBack Ratio" to 2 as shown in the picture? ?? ?? ?? ??
I think yes, try it and see. All that would be wrong is that the spindle speed DRO would be out by double, or half, easy to detect.
What motion controller are you using? There may well be a similar setup in the motion controller plugin.
Answer Hello joaverage.
Currently, the control box for Mach4 is about to be completed, so I have some questions about Mach4, so I asked.
When the control box is complete, give it a try.
The photo shows the control box for Mach4, MB3 and ESS.
The workmanship was good. I'm sorry to brag.
I posted the photo because I thought joeaverage would understand it.
We look forward to your continued guidance.
