Mach Discussion => General Mach Discussion => Topic started by: thorsten026 on November 30, 2021, 10:16:41 AM
Title: Mach3 Output Signal To PC
Post by: thorsten026 on November 30, 2021, 10:16:41 AM
i need help with the ports and pins for the outputs.
the setup consists of a novusun nvem v2 mach3 6 axis
I want to send an output signal to my pc
I have created a custom m code that makes the outputs high. in the mach3 software the output light (output 4) is blinking. I made a breadboard with a led and a resistor 100ohm (output voltage is 5v output amperage is 20mA) if the signal is high the led should be on but this is not the case (even when I measure the circuit with a multimeter there is no current). I think it has to do with the port and pin settings. could someone help me with that?
Title: Re: Mach3 Output Signal To PC
Post by: Tweakie.CNC on November 30, 2021, 12:33:16 PM
Hi Thorsten026,
Sorry but due to their Mach3 license violation this forum does not support Novusun products.
This thread refers; https://www.machsupport.com/forum/index.php?topic=24331.0
