Mach Discussion => General Mach Discussion => Topic started by: Gerry2313 on October 11, 2021, 12:11:38 AM
Title: mach 3 set up
Post by: Gerry2313 on October 11, 2021, 12:11:38 AM
I have a two tress 4 axis 100mhz board and it will not cut a circle  or let you jog two axis at the same time is there a setting in the program for this as each of my motor controllers has its own power supply? running nema34 with 48v 8amp power supply.
