Mach Discussion => General Mach Discussion => Topic started by: Michaelc on September 20, 2021, 10:40:55 AM
Hi, I wish to run a milling machine and a router from one pc and using only one smooth stepper. The motor tuning is different for each machine, so my question is. 1. If I have the milling machine set up in Mach3, under mill. Would it be possible to download a second copy of Mach3 on the same pc, run the same plug in and then set up the router. Thanks,
There is no need to do that just create a new Profile. Then you could create 2 new desktop shortcuts (possibly one called Mill and one called Router). The Mach3 manual gives details on creating different Profiles.
Thanks, will take a look
When I was running Mach3 I had two machines which were run from the same PC - a milling machine hooked up to the PC Parallel Port and a router hooked up through an Ethernet smooth stepper. There was no need for me to swap any cables, I just had to select the appropriate Mach3 Profile and switch on the corresponding machine.
Everything changes and nowadays the Parallel Port has gone, everything is connected Ethernet but because they have become so much smaller I now use multiple PC’s.
