Mach Discussion => General Mach Discussion => Topic started by: 703E5 on September 19, 2021, 04:04:19 AM
Title: A2-8002 VFD set up - any help appreciated
Post by: 703E5 on September 19, 2021, 04:04:19 AM
Hi there, recently posted on the Mach 3 vista/win 7 section, but got no response to this :-
Hi all,
Have finally got axis movement  :D
I am now on to setting up my VFD - model number A2-8022 (https://www.ebay.com/itm/313387171700 (https://www.ebay.com/itm/313387171700)), manual attached - FYI
Was planning on controlling it with a usb to RS485 adapter (https://www.amazon.co.uk/dp/B0721BB8PQ?psc=1&ref=ppx_pop_dt_b_asin_title (https://www.amazon.co.uk/dp/B0721BB8PQ?psc=1&ref=ppx_pop_dt_b_asin_title)) as i would like Mach 3 to control it.
I see that the Huanyang VFD has a plug in written for it, will that work on my VFD?
Any issues anyone can foresee?
and with that any guidance?
Thanks in advance.
Does anybody have any information i can use. Or am i facing ditching my current VFD to replace it with a Huanyang.
Looking into it a bit further, and trying the plug in i can confirm it doesnt work - unless i have missed something - i get a dialogue box saying 'unable to read value' when configuring the plug in.
Do i take it that because i havent had any replies nobody has had any experience with this issue.
Are there any generic plug ins that will work?
Title: Re: A2-8002 VFD set up - any help appreciated
Post by: Graham Waterworth on September 19, 2021, 12:39:47 PM
Most VFD's have a parameter to select the control input, this could be 0-10V, PWM, 0-5V etc usually in the first 15 parameters.
If it has PWM you should be able to set up Mach's PWM output and drive it direct.
This may help :-
https://www.youtube.com/watch?v=AkoKYYB6DuY (https://www.youtube.com/watch?v=AkoKYYB6DuY)
