Mach Discussion => Mach4 General Discussion => Topic started by: gorf23 on September 16, 2021, 06:56:36 AM
Title: lua script help have a problem with converting to number's
Post by: gorf23 on September 16, 2021, 06:56:36 AM
I am read A DRO valve and want to store it in a register i read it alright, but if i try to format it so i loose the values after the decimal point
if i don't convert it to a number i get the error can't use string number expected, so i convert it to a number i get the, error nul value. it is always when i am trying to write the value to the register..
any suggestions?
Code: [Select]
local val = scr.GetProperty("Tool1DRO", "Value")
--wx.wxMessageBox("Val = "..val)
--val = tonumber(val)
--x = string.format("%.1f"..tonumber(val))
mc.mcCntlSetLastError(inst, "val = "..val)
local Pos1reg = mc.mcRegGetHandle(inst,"gRegs0/ToolInPos1")
rc = mc.mcRegSetValueString(Pos1reg,string.format("%.0f",3))
rc = mc.mcRegSetValueString(Pos1reg,string.format(val))
Title: Re: lua script help have a problem with converting to number's
Post by: smurph on September 16, 2021, 11:53:09 AM
It is hard to tell what is what in that script because some of it was remarked out and the last two lines are confusing.  But anyway, without even trying to determine what is wrong with the script, you can fix this easily but just pointing your DRO to that register with the DRO's Register property and use whatever format you want with the DRO's Format Property.  :)
Steve
Post by: gorf23 on September 16, 2021, 12:33:32 PM
thanks not really sure how you mean to point to dro register I'm still in an early lua learning process..
not sure why i either get the error its a nul value after i try to use tonumber(val) and if i don't convert to number i get the error its a string needs to be a number...
This code here works but its not writing to the register it going to the machine.ini file not sure why the conversions work here but not when i am using the registers...
Code: [Select]
local val = scr.GetProperty("Tool2DRO", "Value")
val = tonumber(val)
val = (math.floor(val+0.5))
local Tool2= mc.mcProfileGetString(inst, 'ToolChangeSettings', 'ToolPos2', '0.0000')
if (Tool2 ~= string.format (val)) then
mc.mcProfileWriteString(inst, "ToolChangeSettings", "ToolPos2", string.format (val))
mc.mcCntlSetLastError(inst, "Tool Position 2: updated to Tool: "..string.format (val))
end
thanks
Post by: smurph on September 16, 2021, 02:24:51 PM
What I mean is edit your screen, click on the DRO that is named "Tool2DRO" and edit the Rregister property to point to your "gRegs0/ToolInPos1" register.  Done.  Use whatever format in the Format you wish.  No LUA code required.
Steve
Post by: gorf23 on September 16, 2021, 03:15:57 PM
Thanks Steve,
That was way to easy, i always seem to go down the hard road first..
Gary
Post by: smurph on September 16, 2021, 04:05:57 PM
Glad I could help!  :)  And yeah, I'm a hard road traveler myself.  So I know...  I know.  LOL
Steve
