Mach Discussion => Mach4 General Discussion => Topic started by: daffyduck on August 27, 2021, 12:40:32 PM
Title: MACH4 G31 MOTION WILL NOT STOP ON PROBE CONTACT
Post by: daffyduck on August 27, 2021, 12:40:32 PM
Hello,
I am running Mach4 with Pokeys57CNC
Sorry to post a new topic on G31.  I've tried searching the forum archives and can't find a similar problem / solution.
The problem is when I run this gcode command in the MDI (as a test) the z axis does not stop on probe contact.
G31 Z-10 F50
I can run probing with no issues using the Probing Wizard.  Also the Touch light indicates contact during the move (using the gcode above).
Not sure what I am missing.
Anyone else had this issue?
Thanks.
Title: Re: MACH4 G31 MOTION WILL NOT STOP ON PROBE CONTACT
Post by: smurph on August 29, 2021, 03:49:52 PM
Since probing is a real-time process, it must be handled entirely by the motion controller.  So I would investigate the settings of the Pokeys.
Steve
Post by: daffyduck on August 30, 2021, 03:49:10 PM
Thanks Steve
Post by: gorf23 on August 31, 2021, 12:43:51 PM
I haven't had any probing problems with the pokeys57CNC make sure you are wired to pin 19 on pokeys and on some of the older boards you need to add a i think pullup resistor to pin 19  but been a while and don't remember for sure, the only drawback for me is it won't work with more that one probe connected..
Post by: smurph on August 31, 2021, 03:00:39 PM
Wow.  Good information.  Thanks!
Steve
Post by: daffyduck on August 31, 2021, 06:04:25 PM
Thanks gorf23!
Yup wired on pin 19.  Usually I don't have a problem.  It seems at times either Mach4 or Pokeys "looses itself"  I can't quite figure out how or why.
Post by: KatzYaakov on August 31, 2021, 10:00:07 PM
more then 10 machines ,all pokeys,all have probe ,never had problems,folow pokeys instruction
