Mach Discussion => Mach4 General Discussion => Topic started by: peter g on August 27, 2021, 08:04:03 AM
Hey Everyone,
I would like 2 physical button 1 to enable and the other to disable. These would replicated the onscreen "Enable" and "Disable" button in mach4. Is there a script to assign one of the inputs in Mach 4 to be an "Enable" button?
Peter
I use one button to toggle enable on the control panels here in the shop.
Just put the code in the signal library in the screen load script.
I modified my code so one input will enable mach and the other will disable mach.
[mc.ISIG_INPUT6] = function (state)
if (state == 1) then
local inst = mc.mcGetInstance();
mc.mcCntlEnable(inst,1)
end
end,
[mc.ISIG_INPUT7] = function (state)
mc.mcCntlEnable(inst,0)
end
end,
end
end,
end
end,
Thanks for you help this worked.
Do you know if its possible to do the same for M07(mist on) M08(coolant on) M09(off)?
Peter
Never mind I found a script for it.
Peter
There is a lot you can do with the signal library with inputs. I use the same button to toggle enable, spindle, coolant, and the keyboard. I also have a button for reset, cycle start, and feedhold.
