Mach Discussion => Mach4 General Discussion => Topic started by: stevehuck on August 22, 2021, 03:43:03 PM
I load a gcode file in lathe and the tool path is so small it is about one pixel. I click regen toolpath and nothing changes. I would have thought if I regen the toolpath would be displayed on the XZ plane at a zoom where it can be seen. Are there any known issues that would make this happen. Maybe I need to change the display settings for my video card?
If you look at the circle in the tool path window the little white dot in the circle is my tool path. Regen sets it back to this. If i use the mouse to turn zoom and twist it for a few minutes I can almost see the tool paths.
Tool paths are displaying better.
Is there a setting or an edit to keep the tool paths from moving in the window and have the cutter position move. The tool paths moving like that gives me motion sickness.
You have to edit the screen set and change the tool path's properties. The "Follow Mode" property, to be specific.
Steve
That did the trick! Thank You
I guess that would actually be Mach-Motion sickness!! Haha
Ba da bum!
I think you just may be as corny as I am. :)
