Mach Discussion => Mach4 General Discussion => Topic started by: Toshio.K on August 13, 2021, 05:48:25 PM
Title: There was "Run From Here" in Mach3. In the case of Mach4?
Post by: Toshio.K on August 13, 2021, 05:48:25 PM
Hello everyone.
For Mach4, how do you do "Run From Here"?
When I press the Feed Hold button, the "Run G cord From Here" button turns black and I can't press it.
Please tell me how to start at any position on the G Cord.
Please tell me in an easy-to-understand manner.
Title: Re: There was "Run From Here" in Mach3. In the case of Mach4?
Post by: Greekart on August 14, 2021, 02:02:27 PM
It suppose that you are starting a new program from that line, if you are at feedhold you are not at start..
You need to be in idle mode to use "Run From Here".
Post by: Toshio.K on August 14, 2021, 04:21:09 PM
Answer Hello Greekart.
I clicked on the "Feed Hold" button propertues.
It was in the state of the photograph, but it does not improve.
Please tell me the solution.
Post by: Greekart on August 14, 2021, 07:38:07 PM
Not for the feed hold button..
Just stop running any file, select a line you want to start and press run from here.
Post by: Toshio.K on August 14, 2021, 07:58:41 PM
Yes.
I know how to do that.
in short,
1, Stop
2. Put a line in Line.
3, rotate the spindle.
4, Cycle Start
・ For Mach3
1, Feed Hold
2, designation of arbitrary line
3, Cycle Start
Does Mach4 not work in the flow of 1, 2 and 3 like Mach3?
Post by: Greekart on August 15, 2021, 03:54:22 AM
・ For Mach3
1, Feed Hold
3, Cycle Start
I don't see the point for that and i never had try it.
Change the enable state of "Run from here" to enable always and give a try if it will work.
Mach4 when feedhold is just paused, you can't do much in that state, no motion e.t.c.
