Third party software and hardware support forums. => SmoothStepper USB => Topic started by: phando on June 20, 2021, 01:22:13 AM
Title: ESS -> PMDX-126 and PWM Spindle
Post by: phando on June 20, 2021, 01:22:13 AM
I am almost done with my mach3 transition to mach4 with a ESS and PMDX upgrade along the way. The final piece of my puzzle is spindle speed control with PWM. When I map 'motor on' in the ESS setup and in the Mach4 config, the spindle turns on and off. When I map 'spindle pwm' (there is no Mach4 mapping) in the ESS config, the pin is always 0v. If you are using PWM to control your spindle, I would love to see your ESS and Mach configs around these particulars.
Happy Making
Title: Re: ESS -> PMDX-126 and PWM Spindle
Post by: CNCNewbie24 on April 15, 2023, 03:44:52 PM
Did you ever solve this? Looks like I might have the same problem.
