Mach Discussion => General Mach Discussion => Topic started by: Mortenx on June 10, 2021, 08:40:45 AM
I have a lathe with a C-axis that is engaged with an electrical clutch to the spindle that works very well, I have a macro that enables the clutch and it works fine, then I have an other macro that also homes the C-axis that also works fine, the use of this is when I do more operations that have normal turning in between c-axis operations and these operations needs to be angled to each other. Every time a program calls my macro with homing and it's done I have to press cycle start to continue? guess it has something to do with the homing. My macros are like this:
with auto homing:
While IsMoving()
Wend
DoSpinStop()
While GetOEMled(1000)
Wend
If getoemled(164) Or getoemled(165) Then
Else
ActivateSignal(OUTPUT4)
Sleep(300)
If GetOEMLED(845) Then
Code "G91 G0 C35"
While isMoving()
Wend
End If
Code "G90"
DoOEMButton(1027)
While ismoving()
Wend
End If
without homing:
While IsMoving()
Wend
DoSpinStop()
Wend
Else
Sleep(300)
End If
Hope you can help me out, or give me a clue what to look for.
Regards Morten.
you can try to do a
RefCombination(32)
insteed of
DoOEMButton(1027)
maybe it helps
Thanks for the suggestion, I tried changing my macro, but if I run a g-code where it calls that macro it does not home my c-axis, and if I put it in the MDI it homes the c-axis but after that it kind of hangs for like 20 sec. before mach will accept a new command.
regards Morten
sounds strange. witch Version of Mach3 are you using?
Yeah it's strange, I use Mach3 version R3.043.062 - the recommended version with my ethernet smoothstepper.
Regards Morten
sorry, missed your answer.
for the Moment the only idea i have is, that Mach may be corrupted.
i would try to install a fresh copy.
thanks for your answer, I tried another pc with a fresh mach3 install, same as above.
Guess I have to live with pressing cycle start for now:-)
Regards Morten
Have you tried using the Standard button call DoButton (27)
or
Code ("G91 G28 C0")
While IsMoving()
Sleep(25)
Wend
Thanks for your reply, tried both solutions, the dobutton(27) also waits for cycle start to be pressed if called from a gcode, the other one works if I run it in the editor, but if called from a gcode it just does not home the axis, but does not wait for cycle start.
Regards Morten
witch Motion Controller are you usining?
I am using a ethernet smooth stepper from warp9.
Regards Morten
When you are trying the macro do you have single block enabled?
No single step enabled, just runs the macro. Mach must have a stop function after doing a homing sequence?
here is a piece of code that i am using on one of my machines:
Sub Main()
' TPS 26.06.2021
' do a referece
' new version with OEM Led's
'quit if file is loaded
If IsLoading() Then
GoTo Ende
End If
Message ("automatic reference started")
'reference Z
Message ("Z-axis reference")
DoOemButton(1024) 'Ref Z
Sleep(500)
While GetOemLed(809) = true
Sleep(200)
If GetOemLed(800) Then
Sleep(500)
Message"error while referencing"
End
End If
Wend
Sleep(500) 'wait
Message (" ") 'clear status line
Sleep(200) 'wait
Exit Sub
Ende:
End Sub
it is for z-axis because i have no c-axis.
it runs from VB-Editor and also due g-code call.
in your case it would be oembutton(1027) and oemled(812) for c-axis.
If you run a normal .tap file with the following lines what happens
O0001 (TEST C HOMING)
G91 G28 C0
M30
Thanks for all the answers.
I must have done something wrong when testing G91 G28 C0, because I can make that work, but it uses Mach3 homing setting and not the more precise smoothstepper homing - backing off the sensor at another speed.
When playing with the above, I found out that it homed at another speed and did not back of the sensor, and then it hit me, could it be a smoothstepper homing bug? Yes it is, if I disable the smoothstepper homing settings it works as expected.
I will contact warp9 and tell them about the bug.
Once again, thanks for all your solutions and help, this is a fantastic place.
Regards Morten.
Hi again,
It is not a ESS bug, but a mach3 thing - Andrew from warp9 explained to me...
But the G91 G28 C0 does not work - it just moves the C-axis to machine C0 position, but when the clutch for the caxis have been disengaged for normal turning it does not know where it is, I did not see this when playing with it the last time...
I have asked warp9 if they have a suggestion, and if possible to use ESS for homing only some axis and other use mach3 homing.
I am still open to any input you might have.
Regards Morten
have you tryed to use G28.1 insteed of G28
G28 is a Return to home Position
G28.1 is a Reference Axis
Tried G28.1 and it works from the MDI, but if macro called from gcode, the smoothstepper takes over the homing and wait for cycle start :(
Regards Morten
this with the cycle start must be smoothstepper specific.
i use Buttons 22-24 on my machines (CSLAB controller) within macros and do not have to press cycle start.
Hi TPS,
thanks for your reply, I will link this to Andrew at warp9.
Regards Morten
attached a macro i use on one of my machines.
and this is a typical Header for my g-code
N0001 %1 (Teutoburger GC01 +C01 Tür links)
N0002 G61 (Genauhalt)
N0003 G90 (Absolute Maßangaben)
N0004 G90.1 (I/J absolut)
N0005 M5 (Spindel aus)
N0006 G17 (X-Y Fräßebene)
N0007 G21 (alles in mm)
N0008 G40 (Radiuskorrektur aus)
N0009 G49 (Längenkorrektur aus)
N0010 G50 (Skallierungen aus)
N0011 G54 (Werkstückkoordinaten ein)
N0012 G43 H0 (Werkzeughöhenkorrektur aus)
N0013 M1004 (alle Achsen referenzieren)
i run this macro in all my programs
Thanks TPS,
I have written to Andrew and asked him to check this topic and your post, I will update this topic when I know more, thanks again!
Regards Morten
just a followup, I have been frustrated that my macro with homing is working with other motions controllers, and more or less gave up and accepted that I had to press cyclestart when enabling my c-axis with homing macro, but yesterday evening I tried different things again, and the solution was quite easy, I put a sleep command before the homing command, and it also only worked with the refcombination command, not dooembutton. I could use the sleep down to around 100 and it still worked most of the time, so 500 was on the safe side, tested it around 30 times, so think it's working as it should.
Link to my questions at warp9 forum:
https://warp9td.com/index.php/kunena/8-requests-and-suggestions/8921-mach3-smoothstepper-homing-bug?limitstart=0
snip from my code:
Sleep(300)
Code "G91 G0 C35"
While isMoving()
Wend
End If
sleep(500)
refcombination(32)
'DoOEMButton(1027)
'Call dobutton(27)
