Mach Discussion => Mach4 General Discussion => Topic started by: aroff on May 16, 2021, 08:57:39 AM
Title: Z axis always goes to the top
Post by: aroff on May 16, 2021, 08:57:39 AM
First time run. I load the g-code from Aspire using the Avid Txt save file. When I try to run it sends the spindle to the top and resets
Please..what am i doing wrong. Have watched videos but to no avail
thank you
file included
Title: Re: Z axis always goes to the top
Post by: Cbyrdtopper on May 17, 2021, 10:34:32 AM
Have you set your Tool Offsets and your Z Work Offset?
Your program says it should only go 0.8" above your Z Work Offset.
