Mach Discussion => Mach3 under Vista => Topic started by: aoqeel on May 10, 2021, 12:49:47 PM
I need help, please
There is a problem, which is when running the motors through the "Mach3 Mill" tab, the three motors work, and when operating from "Mach3 Plasma" the Z-axis motor does not work, and with this settings are compatible between them and the video explains the problem
Thank you
