Mach Discussion => Non English Forums => Spanish => Topic started by: tazmahv on April 28, 2021, 10:34:19 AM
Hello, I am here again to ask for help that in this forum has always been good for me
I already installed the laser
Thank you
Now I am at the end of the race I have already done a thousand tests and I am not able to ride the end of the race I think I know position
red and black
but green I don't know where to connect
[img] (https://subefotos.com/ver/?822fa2eda4d6d396d3236638b378dacdo.jpg)
Here is the diagram for the end stop board :-
thanks for reply
I know that green is a sign
what I do not know is where signal on plate mach3 interface board
or I don't know how to configure well
signal is pwm ????
The green wire will go into one of the inputs. The green wire will be 0 or 5V depending on the switch state.
Then configure ports and pins, Input Signals, X Home to Port 1 pin 10 or which of the 5 inputs you have used, It will be one of the following 5 pins 10,11,12,13 or 15
You may need to tick the Active low too.
You also need to put the Black to ground (GND) or 0V and the Red wire to +5 Volt.
ok the final race issue is already solved
Thank you
