Mach Discussion => General Mach Discussion => Topic started by: segul684 on April 26, 2021, 05:01:29 AM
Hello everyone,
I have a problem on my 5 axis CNC with B and C axis Home limits. All axis works fine, the machine is running normally.
The problem is when I press the B Home switch, both B and C are triggered simultaneously in Mach3. And the C switch does nothing.
I tried assigning the same switch to X, Y or Z and works fine. There must be some setting in Mach3 I'm missing.
I attached the video, you can see that I'm pressing the switch on input pin 4 assigned to Y Home and works normaly. Then I assign it to B Home it simultaneously triggers C Home as well.
Hope someone can help.
Thanks!
maybe wron in this screenset, have you tryed with standard 1024 screenset?
